ABS for Tahoe 2007
ABS for Tahoe 2007
Hi all,
i have 2007 tahoe, i like the SUV, its a beast in the desert, but have an issue with the ABS while offroading. how and which fuse of the ABS can be removed so that while offroading the ABS does not interfere.
RE: ABS for Tahoe 2007
ABS off? Why do you want to turn off the ABS?
There is a way to turn off the Traction Control and Stability Trac. And the good fella engineers put a button for it. Pressing the switch once will turn off one feature and holding it for 5 second turns off the other feature (and the whole system) This is used for special cases like when you want to 'rock' your car out of a ditch, or when driving on ice.
ksedchev
December 22nd, 2010 9:12 PM
konasmrz
77
September 29th, 2009 9:54 PM
