Another vibration thread on 07 Burb
Our 07 Burb has a slight vibration in it that almost feels like you hit the rumple strips on the highway, but much much lighter. No noise, just the very light vibration.
It starts at about 60 mph and 1700-1800 rpms, and when you are about to go up a hill and it stops as soon as you accelerate.
I've searched past threads and they range from the torque converter to u-joints and a drive shaft that needs balanced.
Any input?
Any input?
Rotate your tires, its a simple way you can do some self diagnosis...
If need be, rotate the spare into the mix to see if its related to a particular tire/wheel... its one less thing on the check list...
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> youther,
Any aftermarket accessories or modifications?
Louis
GM Customer Service
Louis
GM Customer Service
Chevrolet Forum News
January 14th, 2013 7:38 PM
TricksHoldUp
February 14th, 2012 1:53 AM
greatwhite99
August 27th, 2011 4:00 PM
