Bad alternator noise after speaker install
So I wasn't entirely pleased with my Bose speakers so I decided to upgrade my speakers. I got the Boston acoustic 6.5 components and a re xt800.4 amplifier. I ran my power wire under my car and up through my floor. All my rcas are on the passenger side not running with any power. All my grounds are solid and for some reason I'm picking up bad alternator whine. I went out and bought a ground loop isolator and that worked for a day and then the noise started coming through again. Can anyone help me with this problem?
Are you using the factory radio with a line output converter (LOC) or a aftermarket head unit? Make sure your RCAs are not running by any heavy gauge wires such as fan motor supplies, etc. If you are using a LOC make sure it is secured up away from everything. Make sure your grounding point has all the paint removed from the body. A check to see if you don't have a voltage change from the amp ground input to the (-)battery terminal ( to do this get a multimeter and set it to DC V and put the negative lead to the battery and the posotive lead to the amp ground input (all while it is turned on) and check to see if you get a voltage reading). If you get a reading look for a better ground point. You can also T off and run the radio ground to the body.
SandyB
February 10th, 2014 8:46 PM
2000burb
February 28th, 2012 12:42 PM
jordan61488
November 3rd, 2008 7:36 PM
