Brake bleeding problems
I have a 2007 Tahoe which every year around this time I like to bleed and flush out the brake system. I use a pressure bleeder that works very nice. Well this year I decided to install new bleeders while I was in the process of bleeding the system. All went well until I applied the brake pedal which now I must apply a little more pressure than before and stopping is a little on the soft side. If I pump the brakes several times everything is fine but I need to perform this each time I come to a stop. Originally there was no air in the lines all I was doing was replacing old fluid.I checke outthecompleat system and I have no leaks. Does anyone have any suggestions?
Thanks for your time.
Last edited by Classical Glass; October 19th, 2011 at 7:10 AM. Reason: added more info.
sounds like a little air in the lines. there are other things. possibly brake pads gettin little worn, little thin, master cylinder beginning to leak internally.
crossthread55
September 13th, 2009 9:32 PM
