Brake Controller Plug In
Old Jan 6, 2011 | 10:42 AM
damone's Avatar
Default Brake Controller Plug In
2001 Suburban LT 2500 4x4 8.1L
Can you help me find the controller plug-in under the dash?
Have some questions about the req'd relays/fuses for the tow harness wiring. Is there a relay/fuse needed in the under dash fuse panel to the left of the steering column? The manual says there is somthing needed, but I cannot tell if the fuse is in because the picture in the manual doesn't look like the actual panel. i found the controller wiring and 40a fuse in the glove box, so I figure it was never used for towing. I put the 40a in it's spot in the under hood panel.
Advice? Thoughts?
Old Jan 6, 2011 | 2:19 PM
old dog's Avatar
Default help
maybe this will help e-trailer has some good article's and some vedio's
http://www.etrailer.com/faq-cbc.aspx
Old Jan 7, 2011 | 10:51 AM
damone's Avatar
Thanks old dog.
Coming from a Ford I was looking for a hanging wire. Pretty nice they have it built into the panel.
bobinpa
2007 - 2013 (GMT900)
37
Jan 3, 2016 7:45 PM
mamulan
Aug 20, 2014 8:39 AM
TPM
May 14, 2013 5:58 PM
jasonw75
Sep 15, 2009 10:33 PM
Heavysledz
Oct 24, 2006 9:00 PM
