brake upgrade
do you have to upgrade your brakes if you get 22 in. rims or are factory good enought if so why?
RE: brake upgrade
Factory brakes are fine. Factory brakes were designed to stop that vehicle. The only reason to upgrade brakes is for performance or looks and I doubt you're racing it.
RE: brake upgrade
I personally would. You are changing the rotational inertia. For every inch that you increase wheel size, the rotational force is exponetially increased. So you for 2" over stock you need 4 times the braking distance. For 4" larger wheels you need 48 times the stock force. So I would upgrade brakes, if not a big brake kit, I'd go with R1 Concept rotors and their pads with braided stainless steel brake lines.
RE: brake upgrade
I agree bigger brakes might be a consideration but NO way is stopping distance 4 times longer with 22s over 20s.
He may have made up for the rim height with lower profile tires. In that case rolling mass would be the consideration. |
RE: brake upgrade
ORIGINAL: tahoe07 I agree bigger brakes might be a consideration but NO way is stopping distance 4 times longer with 22s over 20s. |
RE: brake upgrade
I have to agree to....
4X the stopping distance? |
RE: brake upgrade
My bad I ment 4X the braking force.
