A/C clutch not engaging?
Hey gang!
Have a problem - the a/c in my 1995 suburban was replaced last year at a considerable cost. Basically the whole unit needed replacing. Even after replacing it, still wasn't running properly. Wasn't as cold as I would expect it to get (although the mechanic said it was full of freon) and the wires that plugged into the back of the condenser were loose and coming unplugged occasionally (among some other a/c-related problems). Anyways, after a few more trips to the mechanic we had to move - 1,500 miles away. During the move and for a few months afterwards the a/c worked "ok". Not really cold, but at least kept the inside decently cool in hot weather - as long as it was on full blast.
Anyways, long story short, the a/c has stopped working (again). First thing I checked was to make sure the plug hadn't worked loose (seems ok). While it was idling I'd watch the condenser and the clutch would spin for a second or two, then stop for 15-20 seconds, then spin for a second or two, and stop for another 15-20 seconds.
Any idea why it's doing that and how to fix it?
Thanks!
Rob
Thanks!
Rob
Wow...
It's a ghost ship in here.
Not much activity at all. *smile* Well, if no one knows the answer, perhaps someone can give me some suggestions as to some other websites where I might look/ask for ideas?
Thanks!
Rob
Thanks!
Rob
If you bypass the low pressure switch (the one at the dehydrator can) with a piece of thin electrical wire and the compressor runs fine you need a leak test and then recharge of the system. On my 1996 Hoe the compressor has a leak so i search for a replace or a kit of seals here in Sweden.
yep low freon, charge it and check for leaks when i did in my 95 suburban it had about 4-5 leaks,anyways i found this product for ac in cars its called thermonics its amazing i put it into a gmc seirra and that thing gets cold! i put a temp prob in it and it went to about -42 degrees its really and amazing product its local to me so if you need any info just give me an email at levitimmer@yahoo.com i can send info if needed
Nevinryal
October 20th, 2008 10:22 PM
holyspatulaboy
February 20th, 2008 5:26 PM
