Cabin Air Filter? 2006 Burb 1500 LT 5.3
Googled it and seem to have different answers.
2006 Chevy Suburban 1500 LS
I have a loud hum when fan is set on 4 or 5 setting. I was thinking it might be a clogged cabin filter. On 3 it runs fine and that's where I've been running it.
Is it a matter of removing the lower panel to visually check if a cabin air filter is there?
Just trying to save some time by not doing unnecessary work.
2006 Chevy Suburban 1500 LT
https://www.carid.com/purolator/cabi...88&url=2643384
CARiD has the Purolator brand cabin air filter for your ride:
Since I couldn't get a definite answer I decided to get up early before it got hot to have a look.
Removed the lower cover screws and took a peek.
No filter on my model. Just a sealed case.
worn out blower motor?
oilcanhenry (July 3rd, 2020)
Thanks for the info. I already know a cabin filter is available. From what I read a filter depends on your trim level.
What trim level do you have?
BTW, back in my youth, there were no CAF's and my 1998 Chevy K-1500 doesn't have one, which doesn't bother me at all. As a professional driver, many or most commercial rigs back in my earlier days didn't even have A/C, although many owner-operators had them available. Most trucking outfits did not, so you baked in the heat. With a COE rig, the engine was right next to you, not in the front as with most commercial trucks nowadays.
Nowadays, driving a rig is like driving a modern pickup with lots of goodies (blue-tooth, XM radio, cruise-control, ect) as well as A/C too). They even have a system I really hate: the so-called "Auto-Shift" system, which is a device, unlike an automotive automatic transmission, but that does the shifting for you like an automatic transmission, with an electronically controlled servo-mechanism to do the shifting, as traditional medium-duty Eaton truck automatic transmissions won't work in large semi-trucks weight at all.
I'll take a good old 13, 15 or 18-speed manual transmission any day of the week. Autoshifts are for beginners and take forever to get up to freeway speeds'.
There are no badges on the truck. I mistakenly listed my burb as a LT. It is actually a LS model 1500.
Again, no CAF in it which is no big deal.
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
