Can you make heads or tails of this?
Old Dec 6, 2006 | 5:10 PM
  #11
ZX1100F1's Avatar
Default RE: Can you make heads or tails of this?
14-Pin Connector C1:
Pin Wire Color Circuit No. Function
1 RD/WH 340 Battery Positive Voltage
2 TN 201 Left Front Speaker Output (+) (UQ3)
TN 511 Left Front Low Level Audio Signal (+) (UQA/UQS)
3 L-GN 200 Right Front Speaker Output (+) (UQ3)
L-GN/WH 512 Right Front Low Level Audio Signal (+) (UQA/UQS)
4 PK 5149 Voice Recognition Audio Signal (UE1)
5 PK/BK 5152 Low Reference (UE1)
6 WH 7066 Entertainment Remote Enable Signal
7 YE 6817 LED Backlight Dimming Control
8 BK 2550 Ground
9 GY 118 Left Front Speaker Output (-) (UQ3)
D-GN 1947 Left Front Low Level Audio Signal (-) (UQA/UQS)
10 D-GN 117 Right Front Speaker Output (-) (UQ3)
OG/BK 1546 Front Low Level Audio Signal (-) (UQA/UQS)
11 Bare 2011 Drain Wire (UQA/UQS)
12 -- -- Not Used
13 D-GN 5060 Low Speed GMLAN Serial Data
14 -- -- Not Used
16-Pin Connector C2:
1 BN/WH 367 Remote Radio Left Audio Signal (U2K)
2 D-GN/WH 368 Remote Radio Right Audio Signal (U2K)
3 Bare 2099 Drain Wire (UQA/UQS/UK6)
4 L-GN 7396 DVD Video Signal 2 (+) (DNU)
5 BN 199 Left Rear Speaker Output (+) (UQ3)
BN/WH 599 Left Rear Low Level Audio Signal (+) (UQA/UQS)
6 D-BU 46 Right Rear Speaker Output (+) (UQ3)
D-BU 546 Right Rear Low Level Audio Signal (+) (UQA/UQS)
7 D-BU 658 Cellular Telephone Voice Signal (UE1)
8 OG 6978 Amplifier Control (UQA Except Y91)
9 TN/WH 372 Remote Radio Audio Output (-) (U2K)
10 GY 388 Remote Radio Right Audio Signal (U2K)
11 Bare 1573 Drain Wire (U2K)
12 WH 7394 DVD Video Signal 2 (-) (DNU)
13 YE 116 Left Rear Speaker Output (-) (UQ3)
BN 1999 Left Rear Low Level Audio Signal (-) (UQA/UQS)
14 L-BU 115 Right Rear Speaker Output (-) (UQ3)
TN 1946 Right Rear Low Level Audio Signal (-) (UQA/UQS)
15 L-BU/BK 659 Low Reference (UE1)
16 D-GN/WH 7395 Video Mode 2 Signal (DNU)
16-Pin Connector C3:
1 YE 2059 Auxiliary Audio Left Signal
2 WH 2058 Auxiliary Audio Right Signal
3 L-BU 5826 Left DVD Audio Signal (+)
4 WH 5828 Right DVD Audio Signal (+)
5 OG/BK 5831 Remote Infra Red Signal (+)
6 PK/BK 5844 Video Bright Control
7 D-GN 6975 DVD Video Signal (+)
8 PU 2056 Auxiliary Video High Signal
9 Bare 5345 Drain Wire
10 L-GN/BK 5845 Video Module Signal
11 PU 6979 DVD Audio Common
12 Bare 6980 DVD Audio Shield
13 TN/WH 5830 Remote Infra Red Signal (-)
14 Bare 6976 DVD Video Drain Wire
15 WH/BK 5335 DVD Video Signal (-)
16 Bare 5346 Video Drain Wire
16-Pin Connector C4:
1 -- -- Not Used
2 -- -- Not Used
3 D-BU 6760 Center Channel Low Level Audio Signal (UQS)
4 WH 6763 Subwoofer Low Level Audio Signal (UQS)
5 D-GN/WH 817 Vehicle Speed Signal (UVC)
6 PK 6972 Camera Signal #2 + (UVC)
7 L-BU 6973 Camera Signal #2 (UVC)
8 PU 5837 Amplifier Audio Prompt Signal (+) (UQS)
9 -- -- Not Used
10 -- -- Not Used
11 OG 6761 Center Channel Low Level Audio Signal (-) (UQS)
12 PK 6762 Subwoofer Low Level Audio (-) (UQS)
13 Bare 6759 Drain Wire (UQS)
14 -- -- Not Used
15 Bare 5838 Drain Wire (UQS)
16 GY 5836 Amplifier Audio Prompt Signal (-) (UQS)
Old Dec 6, 2006 | 9:10 PM
  #12
TMW597's Avatar
Man! Ask and you shall receive. That was beyond the call there ZX1100F1, but it's going to help a lot of people.
Thank you so much.
TMW
Old Dec 6, 2006 | 9:51 PM
  #13
ZX1100F1's Avatar
I had to type this in all from memory or I would have had it up sooner.
Always glad to help when I can.
Dave
Old Dec 7, 2006 | 12:39 AM
  #14
biglg's Avatar
Ok,
I think I got my navi unit all wired. Dont know if it is right, lol.
First, is there only one green wire with white stripe on the back of the junction?
Secondly, I plugged my plug into the back of the onstar brain before I check the wire number locations, I felt the two wires sticking out of the harness. I assume position to the right is 2, and the wire on the left is 4? (EX: THe plug above in this post, looking at it in the picture you count from left to right? Is this a correct assumption when facing the radio feeling from the right to left of the harness plug while it is plugged in?-------These two wires just go into the top two open plugs on the black radio harness???
Lastly, after wiring some weird stuff happened. It told me to press Checkmark to relearn tire pressure sensors??????? Was my negative battery cable off to long, was this something caused my the navigation install? What is up with this?
Also, my left front parking light stayed on? I unhooked the negative battery cable and that solved that problem. Why did that happen?
Old Dec 7, 2006 | 11:43 AM
  #15
biglg's Avatar
I headed out this morning and drove the Tahoe to the dealership. I was about 3 blocks from my house and the tire pressure sensors were working again. I have no idea, must have a mind of their own!
Dave, please let me know if I plugged the harness up correctly!
Old Dec 8, 2006 | 12:57 AM
  #16
TMW597's Avatar
Hey ZX1100F1,
Referring back to that drawing, where it says pin 4 and 5 on the nav radio. Which harness is it referring to for the pins 4 and 5? Is it still talking about "C4? Because it says pin 5 is going to the junction box by the break pedal, how can it be going to 5 in the nav radio too? Are they supposed to be crossed like that? I'm still just a bit confused and so is my installer. I know it's something simple, but what am I missing?
Old Dec 8, 2006 | 1:13 AM
  #17
biglg's Avatar
4&5 are the holes in the first plug on the back of your navigation unit. I am pretty sure, . I got the harnesses from jpcustoms. I had no problem splicing into the speed sensor wire and plugging that plug into the back of the navigation unit.
However, the other plug i received goes into the back of the onstar box, and let me tell you there isnt much room to work with and especially if you have large hands. So i wasnt able to see, just feel around on the back of the onstar box. I plugged it in, hopefully there is only one open plug in the back of the onstar box??????? I then took the 2 wires from that plug to what I think are the 4 & 5 pins in the first connector on the back of the radio.
Everything seems to be working fine. However I tried a voice command and I never got one to work. What could be the issue Dave? Thanks.
Old Dec 8, 2006 | 1:20 AM
  #18
TMW597's Avatar
I got it! Thanks dude!!!!! It all makes sense now.
Old Dec 8, 2006 | 1:28 AM
  #19
biglg's Avatar
YEs, JP customs had two plugs. Once of which you have. The one plug single wire splices into the green white stripe wire on the back of the junction, then plugs into the farthest left (if facing navigation unit) open plug! That is done. This I am sure of.
NOw, the directions get crappy from here, lol. There is also included another plug with their kit. It has two wires coming out of it. I assume that is the same thing your two wires are for. They told me this plug goes into the back of the onstar box underneath our radio! That box is damn hard to manuever. I couldnt get the plugs out the back to take it out and look at it. So I felt around to my fat hands capability and got it plugged into an open slot!!!!!!!!! IS THERE ONLY ONE OPEN SPOT on the back of the onstar box??????????
Lastly, I took the two wires from the plug. The called them pin 2 and 4 wires, I think! I had already plugged it in so my dumb **** couldnt see which was which. While FEELING around, I assumed wire pin 2 would be the one on the right (right being as the onstar box sits) and pin 4 wire would be the one on the left.
I then took wire 2 and put it into the farthest RIGHT open pin on Connector 1 on the back of the radio. Assuming again that pin 4 is the one to the right while it is plugged in and facing the radio! I took the wire from location 4, assuming it was the right one and put it into the other open hole which I assume is pin 5 on the same far right plug on the back of the radio.
This is damn hard to explain. Like I mentioned everything works except the voice recognition. So either I did something wrong or my voice just isnt working, or possibly I dont know how to work voice recognition. I would love to have some confirmation on my install and whether it is correct. If you can understand my horrible description please advise.
Old Dec 8, 2006 | 1:32 AM
  #20
biglg's Avatar
Looking back at your drawing. You show the nav unit pin 5 on the left, and pin 4 on the right. Is this in the facing the navigation unit position? If your unit was installed in your dash, would pin 4 be on the left, or right of pin 5? ANYONE? This may be where i messed up. I assumed pin 4 was on the right, and pin 5 was on the left.
So, my assumption is that if i were holding that connector in my hand looking down at it starting left to right would be pins 1,2,3,4,5, etc. If i look at it from the top plugged in facing the unit, it would be vice versa, pins starting on the top right would be 1 moving left 2,3,4,5?
