Chime not working on 2008 Tahoe
The seatbelt / key in ignition / backup assist chime on my 2008 Tahoe is barely audible. It works properly about 5% of the time and the rest of the time, It's so faint that it almost can't be heard. Any ideas ?
Originally Posted by cavfan
(Post 222499)
Louis GM Customer Service |
Did you scroll thru the dic choices, I believe one is chime volume.
I did. The chime is set on loud.
In addition to the chime, now my stereo only has sound through the 2 front tweeters and is barely audible
The chime does go through the speakers, might want to check the connections at the back of the radio as CCS suggested... Don't just push it in or wiggle, fully removed the connection, inspect for corrosion maybe even wipe them with an alcohol soaked q-tip and re-install.
(Post 222499)
You just need to replace the speakers. |
