Chime not working on 2008 Tahoe
Old Jul 27, 2012 | 4:50 PM
cavfan's Avatar
New User
Awaiting E-mail Confirmation
Default Chime not working on 2008 Tahoe
The seatbelt / key in ignition / backup assist chime on my 2008 Tahoe is barely audible. It works properly about 5% of the time and the rest of the time, It's so faint that it almost can't be heard. Any ideas ?
Old Jul 31, 2012 | 1:04 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> This may be due to a loose connection or corroded wire. These are just suggestions, it is not a diagnosis. If this is a troublesome issue for you, consider having the vehicle inspected by a certified technician. They will be able to assist you further after an inspection of the vehicle.
Louis
GM Customer Service
Old Jul 31, 2012 | 2:49 PM
blueinterceptor's Avatar
Did you scroll thru the dic choices, I believe one is chime volume.
Old Aug 5, 2012 | 7:09 PM
cavfan's Avatar
New User
I did. The chime is set on loud.
Old Oct 1, 2012 | 5:57 PM
cavfan's Avatar
New User
In addition to the chime, now my stereo only has sound through the 2 front tweeters and is barely audible
Old Oct 2, 2012 | 10:00 AM
The chime does go through the speakers, might want to check the connections at the back of the radio as CCS suggested... Don't just push it in or wiggle, fully removed the connection, inspect for corrosion maybe even wipe them with an alcohol soaked q-tip and re-install.
Old Oct 19, 2012 | 7:22 AM
01burb's Avatar
Your problem is addressed here: https://chevroletforum.com/forum/sil...s-issue-34419/
You just need to replace the speakers.
BNE40
Jul 25, 2022 1:48 PM
retsub
May 11, 2021 7:28 AM
myspacethirdbase
Jul 5, 2017 12:47 PM
adebmart
Oct 4, 2014 11:06 AM
Jperki17
Mar 21, 2013 10:05 AM
