Elec motor noise under dash
I didn't know that existed either. However, I've pinpointed the noise, and it's coming from directly below the instrument panel cluster, not further to the right where the radio is located. Unless it's offset, I don't know that we're on the right track. Anyone else know if that part exists and if so, where it's located?
I have to admit I assumed it was the radio as that is when I would hear it come on, is with engine off, key in accessory and radio on.
HOWEVER I bet with the description Roccodawg just gave it could be a cooling fan for the BCM....
"Below the IP" listing...
2007 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual |
Below the I/P
(1) I/P Trim
(2) I/P Cluster Trim
(3) Floor Panel
(4) Junction Block - Left I/P
(5) Body Control Module (BCM)
(6) Transfer Case Shift Control Module (NP8)
(7) Fuse Block - I/P
Below the I/P
(1) I/P Trim
(3) Floor Panel
