Electric cooling fan running, temp gage reading cold
Old Nov 15, 2024 | 7:04 PM
99fxst99's Avatar
Default Electric cooling fan running, temp gage reading cold
2016 Suburban Z71-last night the electric radiator fan came on while driving. Temp gage was reading cold. Turned the engine off and the fan continued to run for several minutes, This afternoon, checked coolant level-good. Started the engine, radiator fan came on immediately. Let it run to see the if thermostat opened-it did. Let it run for a few minutes until it was up to temperature and the gage still read cold, fan still running. Thoughts? Temp sensor?
Thanks!
Old Nov 15, 2024 | 8:20 PM
Rednucleus's Avatar
When you start it cold does the fan continue to run during the entire warm up time or does it cycle?
Old Nov 16, 2024 | 7:20 AM
99fxst99's Avatar
Continues to run. Also, runs for several minutes after shut-down.
Old Nov 16, 2024 | 7:41 AM
Gumby22's Avatar
Check for codes in the PCM and HVAC module.
An intermittent/erratic/missing ECT signal can cause the fans to default to on in order to protect the engine.
If equipped with an active grille shutter, also check to make sure that it’s working - it should cycle full open to full close immediately after starting.
Old Nov 20, 2024 | 9:18 PM
99fxst99's Avatar
Update-Bad Thermostat. New thermostat and fresh coolant, all is good.
Thanks, guys, for your responses!
Old Mar 12, 2026 | 11:58 AM
Donfields's Avatar
I am having the same issue with my 2015 Silverado. I replaced the temp sensor and it worked fine for about a month. I didn’t change the thermostat. The problem started again today. I guess I will change the thermostat and the temperature sensor again and see what happens?….
99fxst99
Mar 6, 2024 2:01 PM
mlupone
Mar 29, 2023 10:10 AM
Carl145
Cruze
Nov 23, 2020 8:05 PM
atvkid4eva
Nov 12, 2012 8:13 PM
xswinnyx
May 13, 2006 1:01 PM
