-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Engine Noise (https://chevroletforum.com/forum/tahoe-suburban-25/engine-noise-7021/)
AT Tahoe May 4, 2007 3:44 PM
Engine Noise
I got a Tahoe about a month and half ago, and it seems like I'm already have engine problems. When I lightly step on the gas, a whistling noise comes out of the hood, and it also seems there is noise of metal on metal. I took down to the dealership twice, and the first time they said they couldnt figure out the problem. The second time the guy said it is a normal noise, but I dont think it is. They also told me thye havent heard about this complaint. IF anyone else has experienced please let me know, and what can be causing this noise.
ZX1100F1 May 4, 2007 4:14 PM
RE: Engine Noise
Does it make this noise when you step on the gas even if you are in (P)ark? or only when you are moving?
breagle May 4, 2007 11:36 PM
RE: Engine Noise
I have an 07 Suburban and I believe we MAY have the same problem. After about 5 minutes of driving....my truck makes a squealing/squeaking sound when accelerating. It is extremely audible at low speeds(driving through neighborhoods). If it is at idle in park or nuetral, when you blip the accelerator, it squeals then goes away back at normal idle. It sounds to me as if it is some pulley or some bearing problem.
I need to take my truck in for that and for the aspirator on the roof above my head....its making a buzzing sound that I read GM has a bulletin out for. Pretty disappointing for a 47k vehicle with 1800 miles. Guess I see why they are hurting.
engine2 May 5, 2007 1:41 PM
RE: Engine Noise
ORIGINAL: breagle
Say What? Not sure what you mean.
jinzhenheng May 5, 2007 3:52 PM
RE: Engine Noise
i have the same problem since december around 2000 k miles now i have 9600k so far took it to dealer 3 times said the same stuff like cant hearit, normal operating sound,etc.etc.etc. freaking suck paid45k for this. i have owned 97 yukon, 03 escalade esv and never heard a sound like this but engine normal noise. sometime its reallly annoying the little whiming sound. it does it when i m parked and hit the gas little and it whistles and driving at slow speed.. can it be air intake or belts ? i wish they would fix this problem other than that everything if good :)
breagle May 5, 2007 4:11 PM
RE: Engine Noise
ORIGINAL: engine2
ORIGINAL: breagle
Yea...that "speaker looking thing" above the drivers head on the headliner is a part of the climate control system. Here is the GM bulletin regarding it:
Document ID# 1639237
Subject: Buzz Noise From Headliner Above Driver - keywords ac air aspirator cover fan grille HVAC interior microphone sensor speaker temperature vent vibration #PIT3511 - (03/29/2005)
Models: 2000-05 Cadillac Escalade
2002-05 Chevrolet Avalanche
2000-05 Chevrolet Silverado, Suburban, Tahoe
2000-05 GMC Sierra, Yukon, Yukon XL, Yukon Denali
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Dealer or customer may comment that they have a buzz or vibration noise emanating from the headliner in an area that looks like microphone or a speaker.
Recommendation/Instructions:
The plastic escutcheon grill, which is round and about the size of a half dollar and located just above the driver to the left, is the interior ambient temperature sensor. The sensor is used in conjunction with the automatic HVAC (C68). On occasions, this sensor has been known to make a buzz or rattle sound. The sensor uses a small fan to pull air over the sensor. This buzz noise may be intermittent.
Although it may not be possible to alleviate all of the buzz or noise from this sensor, Engineering has found that if the sensor is installed incorrectly that it may bind and cause the fan to make a buzz noise. Remove the sensor and while doing so check for any binding. Reinstall the sensor and re-test. If the noise is still present, the sensor itself may be noisy and require replacement.
engine2 May 5, 2007 11:21 PM
RE: Engine Noise
Very Interesting. I figured that thing was the microphone for the OnStar handfree Calling.:)
AT Tahoe May 6, 2007 2:58 AM
RE: Engine Noise
Yeah, I hear the noise also when Im in Park. Its just so frustrating b/c its a new car, and its already acting up. Im just hoping they will figure out a solution for this really soon.
guessg May 7, 2007 6:12 PM
RE: Engine Noise
Hey zx this sounds like the torque converter issue from a while ago. I have the same noise. It does it in park and while driving at low rpms. What do you think?
ZX1100F1 May 7, 2007 7:16 PM
RE: Engine Noise
ORIGINAL: breagle
ORIGINAL: engine2
ORIGINAL: breagle
Condition/Concern:
This bulletin is not regarding 2007 Tahoe.
