Is factory Nav without Bose possible???
I have a 07 Tahoe LT without the Bose system....Just wondering if anyone knows if and how you can install a factory nav in my truck
https://chevroletforum.com/m_21824/mpage_2/tm.htm. Looks like a no go
ORIGINAL: c21sam
1. Your LT unit will have only a C1 and C2 connector for the current radio. These connectors carry both speaker level and low level (preamp out) signals (research the connector pin signals in other threads). Pull your radio and look at the wire locations in the connectors - are there wires in the positions that correspond to the low level signals?
2. If so then you need to determine if your console harness is prewired for the bose amp; if so, then hunt for one on ebay. Or, you could always custom wire a power amp to the C1 & C2 conectors (you can get connector pins for C1>C4from JP Customs)
3. All you really need electrically for NAV to work are the C1 and C2connectors (and 1 wire off the C4 for the VSS connection). So if you want to take a chance and pick up a NAV unit off ebay (prices have come down considerably over the last few months) you will definitely have a unit that will power up & NAV will work, but you may not have any sound until you address the amplifier issue with either an OEM Bose add or a custom wired power amp.
Hmm, i guess this is a mixed report...from the sticky it seems there are some guys reporting success but with low volume..
so to the Guys who have installed there OEM NAV without bose,can you post the steps, what is required, what aftermarket AMP did you use, etc
ORIGINAL: CaMs
I had one installed on my LS and it was not Bose equipped.Just did the JPC "add an amp" wiring harness, plugged it in, and it works perfectly.
SirKaboomski
June 9th, 2013 10:57 PM
rahb0sse
May 2nd, 2011 12:06 AM
cjasonsmith
February 21st, 2009 10:50 PM
08silveradonb
September 6th, 2007 7:20 PM
