fuel pump
fuel pump
Anyone know what frame mounted fuel pump would match my stock in tank fuel pump?1995 gmc yukon 4X4 5.7 auto...stock pump max free flow rate 60 gph...max pressure range 50psi ...min free flow 50 gph min pressure range 40 psi...thank you for your time
i assume stock pump is going out? an external frame mount wont work inluss you dissamble the pump module and remove pump. but at this point might as well replace stock pump with oe type.
fuel pump
Actually it's still going good but at 195000+ I"m assuming it's a matter of time.I was going to get the parts and have on hand so when the time comes...yes I plan on removing the tank pump but only want to drop it once.
My .2 cents... if you got 195k out of the first one and replace it with an AC Delco pump it will most likely be the last pump you have to put in it....
fuel pump
Suppose I could use a stock in tank pump but I was wanting to try some thing different so if it ever went out again it would be a quick fix...unbolt old pump bolt in new pump...why should it have to be in the tank?Besides I like doing thing different.
Efficiency... having the pump/filter/float in one compact unit saves on parts,weight, manufacturing and repair... a smaller, lighter more efficient pump can be used since the fuel will be used to cool it...Its one operation to install the pump unit at the factory since it all comes pre-assembled...
mangomanj
August 17th, 2014 9:51 PM
22charlie
March 21st, 2013 9:54 AM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
