fuel system lean
My 04 tahoe z71 shows a code 0171 and 0174. I replaced the air fliter and had the injectors cleaned along with the maf sensor. The same codes returned a week later. What is the next thing I should look at? Thanks .
Might want to check for vacuum leaks, look for split or cracked hoses
might try spraying starter fluid around the intake to see if the idle changes....
+1
easy way to rule out vacuum leak is to watch fuel trim at idle and 2500rpm
if the system is adding fuel at idle >+10% but the fuel trim corrects itself at 2500rpm it is most likely a vacuum leak.
if its still adding fuel at 2500rpm it not a vacuum leak, check fuel pressure.
at 2500 system vacuum is lower and more total airflow negates the vacuum leak.
anyone had any luck cleaning mafs? I guess its worth a try but I have never saved a bad maf by using maf cleaner spray so far.
GMLover,
My '03 Tahoe presented the same codes (P0171 and 74). Simple fix. Fuel filter. I didn't see you changed it in your posts.
Changed mine out and codes never came back. Fuel trims are back down to -2 to 0%. Unfortunately I didn't look at them before the filter but I think if they go to 8-10% to maintain proper air/fuel mix then those 2 codes will set.
Give it a shot.
~Ronbo
Give it a shot.
~Ronbo
blacknblue#2
15
January 29th, 2021 4:21 PM
eptorgison
January 30th, 2013 8:06 PM
surfandride
January 16th, 2011 10:05 PM
