Fuse location help
Fuse location help
I have a 2002 Suburban with leather seats, power front seats, and seat heater. The driver seat no longer moves and the seat heater only works on low, no high. I figure before I start replacing seat motors, the dealer said $1300 for parts alone, that I’d try the fuses. Anyone know which fuse I should start with, instead of pulling them all until I find one? I’d rather not pull what I don’t need to. The seat location is fine for me at 6’4”, but the 5’8” wife is at a little disadvantage lol.
Thanks,
Jay
Thanks,
Jay
The seat motors get the power from the left side instrument panel fuse block circuit breaker "SEAT CB" .
If the passenger seat moves then the circuit breaker is OK, as it powers both sides.
I'd also check the connectors under the seat.
Thanks for the info. I wasn’t sure if both seats are on the same fuse, but it makes sense that they do. I’ll check the connections, but I imagine it’s a motor. Wouldn’t surprise me on a 16 year old vehicle.
Does the seat move at all (up down forward backward)? There are 3 motors moving the seat. It's unlikely all 3 would go bad.
Don't forget to check the switches.
tap the motor housing with a hammer while holding the button in a position to close the switch (any direction as long as the seat is not at the end of its range in that direction). when the motor brushes wear, sometimes a tap will move the brush to make better contact and the motor will move. If it does start working; it will eventually fail again, replace the motor.
The only thing that works is the lumbar support. The chair doesn’t move forward or back, the seat back does not tilt in either direction, and the seat cushion will not tilt. The seat warmer only works on low.
Correct me if I’m wrong, but if it were just the contact with the brushes, shouldn’t the motor still make noise and just not move? There’s no sound at all. Every once in a while it would only move an inch at a time, then go back to moving regularly, but now that isn’t even an option anymore.
If the passenger seat moves (power is getting to the seats), you'll have to get under the seat to find the problem. While pressing the switch, check for power at the motor (red & black wires) with a meter or test light.
You can test the motors by unplugging and applying power to the red and black wires going to the motor. If the motor stalls trying to go the wrong direction reverse the power leads feeding the motor.
Check to see that the wires into the connector going to the switches have not been pulled apart, especially the orange and black wires (12v and ground).
