help with laundry list of trouble codes
i will start off with i bought a 2003 Chevrolet Tahoe Z71 with a fabtech 6in lift with 35x20 rims. i bought for a steal at $3500 it has been in several wrecks.
it has the 5.3. i have already replaced the brakes on all 4 tires, both belts, cleaned the evap vent, unclogged the rear ac vent tube, replaced the blenddoor on the rear ac system, replaced both ujoints on the rear driveshaft.
i went to the parts store and had them pull my engine codes the first time i had over 44 codes.
i had them cleared and went back 2 days later to see what codes came back i had 35 come back several codes had come back in multiples.
it seems that alot of them are connected in one way or another and i would like to get some opinions on how to repair and some input on what you guys think.
1. C0226- left front speed sensor
2. C0227- left front speed sensor
3. C0225- left front speed sensor
4. C0222- right front speed sensor
5. C0221- right front speed sensor
6. U1000- loss of comm
7. C0300- 02 sensor
8. C0305- tccm reprogram?
9. C0374- tccm reprogram?
10. C0306- transfer case motor?
11. C0321- transfer case motor?
12. C0327- transfer case shift motor/ encoder?
13. C0359- low range?
14. C0379- front axle short to ground?
15. C0550- abs module
16. B0790- neutral indicator
i know thats alot of codes but any help with input or suggestions would be great.
thanks in advance.
7. C0300- 02 sensor
thanks in advance.
thank you 73shark.
and from what research i have done so far the u1000 code is a secondary code that kicks in once a module stops communicating within the canbus system which in my case i am thinking it is my abs module, that triggerd the u1000 code.
now all of the transfer case codes i am thinking the previous owner did go mudding and i have washed about 5 pounds of mud out from under the tahoe and i think the water got into some not so good places.
and the previous owner also took out the radio and left me with enough 4awg battery cable i could have relocated the battery to the rear cargo area.
from what i am looking at i am thinking i need to do is crawl under the vehicle and go through every plug for the front axle, and tcase i can find and clean and put dielectric grease into the plugs and look for faulty wiring and bad grounds as my next step.
does anyone know of any thing else i need to be looking for while i am under the vehicle?
