HELP - Wheel Measurements Info Needed
My 06 Tahoe Z71 is set to arrive this weekend...let the building begin!
Wanting to get new wheels but need the following bits of info:
Back Spacing:
Bolt Pattern:
Stud Size:
Lug Nut Style:
Center Hole Diameter:
I want to keep the same backspacingthis is currently on the 17" wheels now but I just don't know what the size is and can't seem to find the info out online anywhere.
All help would be appreciated!
Back Spacing:
Bolt Pattern:
Stud Size:
Lug Nut Style:
RE: HELP - Wheel Measurements Info Needed
when ya get it pull the wheel off lay it outside faceing the ground you may have to deflate the tire but take a strait edge and lay it across the rim and take a tape mesure and measre from where the rim bolts up with the truck to the strait edge thats is your backspacing
this website will help you with your bolt patern
http://kleenwheelsincolor.com/kwic_d...e_diameter.htm
thisshould help you with the back spacing
http://filmat11inc.com/wheelntiretech.aspx
or try these
https://www.rsracing.com/tech-wheel.html
hell go to discounttire.com that might even help you
or try these
gabriel fuentes
February 3rd, 2011 3:28 PM
