ignition coil ID code
Im going to be replacing my spark plug wires. Upon research I have found I need the ignition coil stamp on the coil. I removed the plastic shroud on top and found a number (1256150) stamped on the metal plate but this number does not correspond with any wire set I have found. The two numbers listed on acdelco sets are : 12558653 and 19006218. Am I looking at the wrong spot for this coil stamp or can I just find out which specific set to get by my vin?
