Left turn signal doesn’t work, right turn signal is fine
I have a 2003 Chevy Tahoe LTZ. My left turn signal completely stopped working in the front, rear, mirror and the instrument cluster, even with the hazard lights. I’ve already checked the bulb connections and the fuses and nothing is wrong. I do have aftermarket LED lower headlights on it but the right side works fine so I don’t see that being the problem. Considering the fuse isn’t blown I wouldn’t think it wouldn’t be a bad ground right? I NEED HELP!!!!
maybe a bad turn signal switch. each bulb has its own ground so its unlikely that grounds for the front , rear, mirror and cluster has all gone bad at once. check for power out of the switch.
repairman54 (March 15th, 2020)
or
Plus electrical schematics
and some know-how
https://www.fluke.com/en-ca/learn/bl...roubleshooting
