Lifter ticking after rebuilding engine
Hello to all still at it with this burban. So I was going to swap motors but after speaking to the mechanic who diagnosed the bad lifter I decided to rebuild.
things done, timing and chain new cam new lifters new high flow oil pump Rebuilt heads And the obvious all new gaskets Just did the 1st start this evening and this thing is ticking like a typewriter, oil pressure was at 60ish once warm droop to below 20psi. engine idles fine no misfires but is loud with the tick anyone know what could be the cause or what I did wrong? I am getting a code for bank 1-2 too lean which I’m going to dig into this tomorrow. |
i have a 2008 suburban with the same exact problem with the ticking, was wondering how you made out with yours, if you got the problem resolved, i can not figure mine out
Originally Posted by Spoonie
(Post 502340)
yes I did, all new OEM lifters from Rockauto check your cam while you’re in there as well. Should be gtg. mine is quite and smooth solid rig now. |
Thanks, I will give it a try
(Post 502351)
Spoonie: Welcome to the forum.í
