Last edit by: IB Advertising
Browse all: Towing & Hauling Guides
- Chevrolet Silverado 2014-Present: Towing and Hauling General Specification
Important information to understand your Silverado
Max towing
#11
I have a 2010 1500 suburban 3.08 axle ration. My towing capacity is 5100
But I added a transmission cooler. Can I tow a travel trailer that is 5400 dey weight. I have weight distribution hitch. If j had the 3.42 with transmission cooler than the towing capacity jumps to 8100
But nothing is mentioned in Manuel for 3.08. Any thoughts? My GCWR is 7400 lbs. I would be well under this weight with trailer and family loaded.
#12
Check your PRO codes in the glove box for your vehicles GVWR, my 2007 Tahoe with the GU6 Rear axle, 3.42 ratio, is C5Y GVWR, 7100 lbs. (3221 kg)
C5A : GVW RATING, 4900 LBS
C5B : GVW RATING, 15,000 LBS
C5C : GVW RATING, 5000 LBS
C5D : GVW RATING, 4600 LBS
C5E : GVW RATING, 5400 LBS
C5F : GVW RATING, 8500 LBS
C5G : GVW RATING, 5600 LBS
C5H : GVW RATING, 6900 LBS
C5I : GVW RATING, 8050 LBS
C5J : GVW RATING, 6000 LBS
C5K : GVW RATING, 5175 LBS
C5L : GVW RATING, 5370 LBS
C5M : GVW RATING, 6100 LBS
C5P : GVW RATING, 6250 LBS
C5Q : GVW RATING, 6400 LBS
C5R : GVW RATING, 5800 LBS
C5S : GVW RATING, 6600 LBS
C5T : GVW RATING, 4200 LBS
C5U : GVW RATING, 6800 LBS
C5U : GVW RATING, 6100 LBS
C5V : GVW RATING, 6850 LBS
C5W : GVW RATING, 7000 LBS
C5X : GVW RATING, 4650 LBS
C5Y : GVW RATING, 7100 LBS
C5Z : GVW RATING, 7200 LBS
C6A : GVW RATING, 7300 LBS
C6B : GVW RATING, 4785 LBS
C6C : GVW RATING, 7400 LBS
C6D : GVW RATING, 10100 LBS
C6E : GVW RATING, 7500 LBS
C6F : GVW RATING, 5150 LBS
C6G : GVW RATING, 7600 LBS
C6H : GVW RATING, 4350 LBS
C6I : GVW RATING, 4850 LBS
C6J : GVW RATING, 5100 LBS
C6K : GVW RATING, 20000 LBS
C6L : GVW RATING, 8000 LBS
C6M : GVW RATING, 5950 LBS
C6N : GVW RATING, 8200 L85
C6P : GVW RATING, 8600 LBS/3, 900KG
C6Q : GVW RATING, 6875 LBS
C6S : GVW RATING, 8900 LBS
C6U : GVW RATING, 9000 LBS
C6U : GVW RATING, 5950 LBS
C6W : GVW RATING, 9200 LBS
C6X : GVW RATING, 4810 LBS
C6Y : GVW RATING, 9600 LBS
C7A : GVW RATING, 10000 LBS
C7C : GVW RATING, 10500 LBS
C7E : GVW RATING, 11000 LBS
C7G : GVW RATING, 11500 LBS
C7H : GVW RATING, 6400 LBS/2, 900KG
C7J : GVW RATING, 11800 LBS
C7L : GVW RATING, 12000 LBS
C7M : GVW RATING, 14100 LBS
C7N : GVW RATING, 12300 LBS
C7P : GVW RATING, 16000 LBS
C7Q : GVW RATING, 10200 LBS
C7S : GVW RATING, 14600 LBS
C7U : GVW RATING, 5200 LBS
C7V : GVW RATING, 26500 LBS
C7X : GVW RATING, 5850 LBS
C7Y : GVW RATING, 4700 LBS
C7Z : GVW RATING, 4537 LBS
ckeysor
34
November 28th, 2015 1:14 AM
louann11chevy
January 10th, 2012 12:23 PM
Nyron
June 28th, 2010 11:55 AM
ahjah9
December 7th, 2006 11:20 PM
