Multifunction switch replacement horn going off
I just finished up replacing the switch on a 1996 Suburban and when I hooked the battery back up the horn goes off. I took the airbag off and checked the pin that's under the airbag For the horn and reinstalled it. I hooked the battery back off and it is still going off. Does the horn pin go in a certain way or is it possible I have screwed up some of the wiring? Thanks for your time and help!
David |
Figured it out. The PB Blaster I used to help take wheel off was down in the contact area. Cleaned it out and it solved it.
hi i have a 2007 malibu and the horn wont stop is it dificult to remove the air bag
horn
maybe, but you can always cut the wire on the horn side ;)
