Multifunction switch replacement horn going off
Old Feb 26, 2012 | 9:59 AM
mdoc111's Avatar
Default Multifunction switch replacement horn going off
I just finished up replacing the switch on a 1996 Suburban and when I hooked the battery back up the horn goes off. I took the airbag off and checked the pin that's under the airbag For the horn and reinstalled it. I hooked the battery back off and it is still going off. Does the horn pin go in a certain way or is it possible I have screwed up some of the wiring? Thanks for your time and help!
David
Old Feb 26, 2012 | 1:37 PM
mdoc111's Avatar
Figured it out. The PB Blaster I used to help take wheel off was down in the contact area. Cleaned it out and it solved it.
Old Apr 9, 2012 | 12:15 PM
breesdad51's Avatar
New User
Awaiting E-mail Confirmation
hi i have a 2007 malibu and the horn wont stop is it dificult to remove the air bag
Old Apr 9, 2012 | 12:27 PM
SabrToothSqrl's Avatar
Default horn
maybe, but you can always cut the wire on the horn side
northey87
Silverado DIY and Useful Threads
26
Apr 10, 2026 9:38 PM
dphilbrick1969
Jan 8, 2010 5:40 AM
60jerry
Nov 7, 2009 8:35 PM
isaac_22
Dec 26, 2007 9:23 PM
