Need Help with RSE wiring harness part numbers
I have a 2009 tahoe that I got with NAV CD player. I just swapped it out with NAV DVD unit. I have headrest DVD players installed aftermarket. I am looking for the part numbers for the RSE wiring harness so I can connect the video out of the DVD player to the inputs of the headrest monitor and get the auxiliary input for use on both. My local dealer is having issues finding the part. Can anyone give me the part numbers that I need for the harness or connectors.
Don't waste your time or money looking for the factory harness.
Get an RCA lead that will run front to back. Cut the end of and strip back the insulation a bit. Get a couple terminals from the parts dept and crimp them on, then insert them into the radio. Connector 3, pin position 7(+), and 15(-). Plug it into the input of the headrest and your good to go
Tell the parts dept you need 2 terminals. part #15359541 From tray # 4
RayRay
February 21st, 2010 9:51 PM
