need help with surburban pitman arm
Old Mar 4, 2014 | 5:49 PM
vaughntsnyder's Avatar
Default need help with surburban pitman arm
I just put a new pitman arm on a 96 surburban and I can't get it to tighten all the way down no where near as close to the steering gear as the old one.It is about 7/16'' verses about 1/8''.Is this ok?
Old Mar 4, 2014 | 7:54 PM
Sergio Lisboa Machado's Avatar
Hi, probably you should heat the pitman arm near the steering box, you can use torch, but be careful with the steering box seal, it can be damaged.
Muskovin
Feb 24, 2013 5:13 PM
lynchcrew
May 19, 2011 9:40 AM
Rivernut
Dec 4, 2007 4:38 PM
el_muerte
Mar 19, 2007 1:05 AM
