Need New Replacement Cap for Escy Style Luggage Rack
I have an '07 Suburban which I did the upgrade to the Escy Rack. This winter when clearing off some of the many feet of snow that ended up on top of it, we must have knocked off a painted cap. Now that Spring is here it's time to replace it..
It's a passenger side front for a Suburban (or extended length) rack.
The color is the Tahoe/Suburban White.
Does anyone have a part number (unpainted) or have a source to purchase a painted replacement?
Thanks.
Thanks.
I found from earlier posts 4 part numbers for caps. I have the extended rack for ESV/Suburban/XL. Could someone reliably tell me if these fit the extended as well as the standard length and which one would be passenger side front? Or even which two would be front? I can then order it direct from GMparts
Here are the 4 numbers:
25787589
25787590
25787559
25787560
Thanks!
25787589
25787590
25787559
25787560
Thanks!
Professional Mechanic
It would be a good idea to call the dealer to atleast get the part number. However the are less than $30.00 so makes sense to get it fron them. No shipping costs and if the wrong one comes in they will get you the correct one with no addtional shipping costs
Contacted dealer. Dealer found the similar part #s I got off here, and was able to tell me which one was the front passnger. He then told me they are not selling the caps seperately anymore and I would have to buy the entire kit. I took the part number he gave me and went to GMParts and put it in the part # search. It linked me to a new part number and it is called a "cover kit" with a similar price (slightly higher). Should be here soon, if it is the right one, I will post the new part numbers and their location on the vehicle if anyone needs to replace as I have to.
Just FYI.
Just FYI.
Seagrave7
October 4th, 2007 8:18 PM
