need some help with coolant flush.
good evening gentle folks.
i'm fixing to do a coolant flush on my 2002 suburban. i bought the new coolant bottle.
i was wondering if anyone has a complete write-up with specific directions for a proper coolant flush on this suburban. it's my wife's.
please and thank you in advance!
regards,
dom
regards,
dom
First you have to locate the drain plug normally found on the lower right of the radiator. Then you wait till all the fluid in there drains out then what I do is stick a water hose in the radiator cap till it runs clear then I take out the hose retighten the drain plug and fill the radiator with coolant. If you don't have a drain plug just pull the lower radiator hose.
Also, reason I asked for instructions is cos I wanted to cover all the bases and ensured I did not miss anything.
Thanks!
JoeBlow
11
April 27th, 2012 11:08 AM
