New 5.7 Vortec engine
Old Sep 27, 2008 | 6:25 PM
Eric Kropp's Avatar
Default New 5.7 Vortec engine
So I am almost done installing a new Goodwrench engine in my 1999 Suburban and I have couple questions for you seasoned pros. The manual says there is no ignition timing set or adjustment. What I gathered is you bring #1 to TDC and point the rotor towards #1 on the cap and call it good. Sound right? Also, what do most you think as far as oil is concerned. I was thinking I would go full synthetic from the git-go. Any of you guys changed one of these?
Thanks for the help,
Eric
Old Oct 19, 2008 | 3:31 PM
SabrToothSqrl's Avatar
Default RE: New 5.7 Vortec engine
a whole new engine? just for fun? a 99? I'm no pro, but i wouldn't mind some engine swap pics...
how hard was it? I hope to pick up an old wrangler cheap, and drop a 350 or similar in it
Old Nov 20, 2008 | 5:18 AM
hquick's Avatar
I'm running full synthetic Mobil1.
You'll need to do a crank relearn.
Yes about the timing and aligning of the dizzy....BUT...
You'll need to get a scanner hooked upto it and have the cam/crank correlation angle (CMP retard) set at +/- 2deg
Old Nov 25, 2008 | 9:49 PM
jkgray80's Avatar
You are right about timing. All you can do is get it close & then use a bi-directional scan tool to check cam retard. Should be 0 +/-2 degrees at around 2K. Then perform a cam/crank relearn. If you get it close it will run but the 'Check Engine' light will stare you down.
ford with a chevy
Apr 11, 2013 1:37 PM
jaxontipedeau
Feb 6, 2011 11:48 AM
yellow73bb
Jul 6, 2007 3:58 PM
loft
Nov 3, 2006 8:21 PM
