New Transmission
pulling a 29 ft RV Trailer with 2010 chevy 1500 suburban 4x4. transmission temp went above 200. it reached up to 225.
is transmission ok if I change oil and filter or is transmission need to be replaced |
I wouldn't be too concerned unless it was sustained for a long time. How does the fluid look? If you don't have the additional trans cooler, I would get it. Your temps will likely drop 25 degrees. I would have any work done performed by the dealer and not yourself, unless your very automotive mechanically inclined. It will be a little more expensive than you will want it to be, but compared to what it takes to do a trans oil/filter change or adding the additional cooler...it will be worth the expense imo.
And since I can't tell from your post, changing the regular "oil and filter" has nothing to do with the transmission. Just fyi. |
Unless the transmission is acting up change the fluid and don't worry about it. I also tow a travel trailer with my burb. I have the factory tow package and I added an additional transmission cooler. If your fluid is still red it's probably OK.
