No cel
Old April 6th, 2010 | 12:45 AM
6in tahoe's Avatar
Default No cel
Ok got a problem that is bugging the hell out of me right now not sure what it could be maybe some one else does. My check engine light does not work. It came on for the first time a couple days ago so i imideatly hooked a code reader to it. checked code but did not clear it. and now it dosnt work again. i kknow it should be on due to the code. is there a common short in the eletrical that i should check for. and if the light dosnt come on will a scan tool read if there is a code?
Ok just to clarify
light wouldnt come on period during start up or running.
randomly came on was able to read the code. but didnt reset it.
now dosnt come on again and scan tool reads no error codes.
Old April 6th, 2010 | 1:35 PM
What was the original code?
If the problem goes away, the DTC will reset after a certain number of run cycles.
Old April 6th, 2010 | 8:05 PM
6in tahoe's Avatar
its not that the code has reset its that the light dosnt come on period. i know the light is suppose to come on when the ignition is turned to the on position without starting it.
Old April 8th, 2010 | 6:09 PM
Maybe that particular bulb is burned out then.
Old April 8th, 2010 | 6:17 PM
MDTAHOE's Avatar
Professional Mechanic
X2
That is the most common cause. Close second cause is some hack removed the bulb.
Old April 18th, 2010 | 10:40 PM
6in tahoe's Avatar
except on these gauges the cel light isnt removable and i tried swaping back to my stock guage set and it didnt solve the problem.
timdogg1313
July 18th, 2011 6:43 AM
wildman
January 6th, 2009 8:20 PM
rickybobby
August 12th, 2008 7:38 PM
burnowt00
July 1st, 2008 3:50 PM
redhotneon
April 16th, 2007 10:31 AM
Quick Reply: No cel
