Is this normal when buying new wheels?
Hello,
I have a 2013 3/4 ton Suburban. Since all the wheels had rust and a lot of damage, I decided to order some new OEM wheels from my Chevy dealer. I also ordered new (mounted) tires.
I asked the dealer to mount and balance the four wheel/tires before shipping them to me. The wheels (with their mounted tires) just arrived. These wheels have some rim weights on the inside face of the wheels, plus some stick on weights closer to the outside face of the wheel.
On the old, damaged wheels, I never took the time to check whether they had the stick-on weights; I did notice some of them had rim weights.
So my question is : Is it normal to combine rim and stick-on weights on new OEM wheels? Is this how they come from the factory on a new vehicle?
Thanks for reading.
Thanks for reading.
They did a good job.
anytime a clip on weight is installed on a rim it scratches the finish. this will allow corrosion to set up on the scratched surface. the rear of the rim is not seen so weights can be hammered on there. putting a stick on weight on the visible side takes more time but saves the rim.
always ask the tire shop to use stick on weights on the outside if you have aluminum rims. steel rims does not matter.
I have alloy rims on my 06 taurus and they are in mint condition...they have never seen hammer on weights except the original ones from the factory.
they can come in either configuration from factory. Anytime an alloy rim comes from factory will hammer on weights on the outside. have sticks on weights installed for all future balancing and stick on or hammer on weights on the inside.
some installers statically balance the wheels...which places the weight only on the inside. it is fast, easy and saves scratches but dynamically balanced wheels are a better method. So make sure they dynamically balance your wheels using stick on weights on the outside.
