Oil pressure gauge 2003 tahoe
2003 Tahoe with 200k mi. Oil pressure gauge began pegging out today. Happened at all speeds. What are the potential issues with this, along with cause(s) and fixe(es)?
Welcome to the forum.,
Is the engine running and sound normal?
I would suspect the sending unit is defective or the gauge is bad...
replacing the sending unit would be the easiest shotgun fix without having the actual oil pressure checked...
New User
Awaiting E-mail Confirmation
I HAVE A 03 TAHOE AND THE OIL GAUGE READING IS ON 80, JUST HAD OIL CHANGED THE SAME DAY I NOTICED IT, BUT THE NEXT DAY THE OIL PRESSURE LOW LIGHT CAME ON FOR ABOUT 5 SECONDS AND WENT BACK OUT..
WHAT DOES THIS MEAN??
Has anyone had the same problems on a 2003 Chevy Tahoe??
get back @ me..
Mrs. Kim
get back @ me..
Mrs. Kim
New User
2003 Chevy Tahoe
My oil pressure low light came on, the oil gauge reading has been on 80 for two days before that light had came on but I had the oil changed the same day I noticed the gauge was on 80 and it still want move and I haven't drove it since I've noticed this. What could it be and do I need to take it to a dealer shop? Can I still drive it?
Mrs Kim T
scared to drive with my 4 girls
Mrs Kim T
Welcome to the forum...
First off check the oil level and verify that the level is good on the dip stick
Too much oil can give a high reading... i suspect the problem you are having is with the sensor much like the original poster had on this thread...
If the engine is not clattering or knocking the oil pressure is probably okay, it should be addressed promptly though....
I have a similar problem. Chevy Avalanche 2005 5.3L oil pressure gauge pegged at 80. Even with engine off but switch on so fan runs gauge go to 80. Clearly this is a bad reading. How can I quickly determine if it is the gauge or sensor? Is the best option take it to the dealer.
Steelman512
June 8th, 2023 2:51 PM
not_a_car_dude
September 15th, 2013 7:41 PM
