Popping sound when turning
I have 04 Suburban and at the beginning of the year we had the rear differentle (sp?) replaced. Not long after that everytime we made a right turn or pulled out of driveway, we would hear a popping/creaking noise up until we straightened out the steering wheel. We don't feel it in the wheel or in vehicle when it makes the sound though.
Not long after we noticed the noise we had new tires put on and the sound went away, so we figured the tires was causing the problem. Now the sound is back again and no matter what way we turn the vehicle it now makes the same popping/creaking noise. Anybody know what it could be before I go to a mechanic. My husband thinks it could be the wheel bearings. |
I had a similar problem on my 2002 and replaced the steering shaft and it seemed to fix it. My dad and I did it ourselves, wasnt to hard if I remember correctly.
But my steering is still kinda sloppy, need to get that figured out. Wasnt there a recall for the steering shaft? |
Check the coil spring rubber seats. They are probably worn through causing metal on metal contact.
Check your sway bar bushings. Check your upper and lower ball joints. lift the front tire off the ground and give it a push and tug to test the ball joints and bearings. |
is sound from front or back?
Have the intermediate shaft checked. If it hasn't been replaced w/ the new design, could be the source of the noise.
Originally Posted by sheymom26
(Post 304232)
Not long after we noticed the noise we had new tires put on and the sound went away, so we figured the tires was causing the problem. Now the sound is back again and no matter what way we turn the vehicle it now makes the same popping/creaking noise. Anybody know what it could be before I go to a mechanic. My husband thinks it could be the wheel bearings. David g. :D |
