Rear brake pad wear
Rear brake pad wear
I have an 07 Suburban. In 2015 at 78,000 miles the passenger side rear inside brake pad was worn down to the metal backing plate, outside pad still had about 1/8" of friction material left.. I suspected a sticking caliper. I changed the caliper, resurfaced the rotor and replaced the pads on both wheels. Now in 2018, 117,000 miles and the same thing has happened. Rear driver side pads still have plenty friction material left. The front pads are original. It seems now it is an issue other than a sticking caliper. Anyone have a similar issue.
I'd pull the calipers off and redo the brake pistons, flush the entire brake system out and install DOT 3 or 4.
