Rear Diff oil type.
Old Jul 20, 2009 | 10:09 PM
Beebe's Avatar
Default Rear Diff oil type.
I'm planning on changing the rear diff. lube on my 2000 Silverado, and my 2005 Suburban. Both have 4 wheel drive. According to the owners manual it recommends synthectic 75W-90 oil. I went to a local parts store and they did not have 75W-90. They had 75W-140, and 80W-90. I was told by the owner of the store that the Amsoil 80W-90 will work just fine. Just wanted to get some other opinions. The oil does meet the GM requirements. Thanks.
Old Jul 20, 2009 | 10:14 PM
suzuki-guy's Avatar
I used 80 90 but is it a possi unit? If it is you need the GM possi additive or you will get possi clutch chatter.
Old Jul 20, 2009 | 10:23 PM
Beebe's Avatar
I don't know. How do I find out? The label on the back of the qt says it complies fith GL-5 and GM specs.
Old Jul 20, 2009 | 10:36 PM
suzuki-guy's Avatar
I think if you look at your RPo codes in your glovebox there should be a G80 Which is possi and you will need the GM additive!
Old Jul 21, 2009 | 6:50 AM
MDTAHOE's Avatar
Professional Mechanic
Jack the back of the truck up so the back wheels are off the ground. Put it in neutral spin a back wheel by hand, if the wheels go the same direction put the addative in. If one wheel goes foward and one goes backwards you do not need it.
Old Jul 21, 2009 | 9:51 PM
15 Year Member
I thought the G80 was an Eaton locking diff, not a clutch type. But I don't know when they started using it.
chevy619
11
Dec 30, 2011 10:57 PM
AWDINNE
Dec 29, 2010 12:22 PM
jgray152
Jul 12, 2010 8:22 PM
jljbtm
Jan 25, 2008 10:08 AM
enovativ
Apr 9, 2007 12:20 AM
