rear diffferntial
Old December 11th, 2013 | 5:33 PM
rcav2013's Avatar
Default rear diffferntial
hi..have a 2013 suburban LS 4x4 and my truck does not have the locking rear/limited slip diff..i would like to add this feature to my suv. I would like to know if I have to swap out my rear and put one in that has the limited slip or can I just add the gear kit for the limited slip. also if anyone knows the part number for the rear the has the locking rear/limited slip. it is the same rear that comes standard with the LT or LTZ model. it has 3.08 gear ratio...thank you rob
Old December 11th, 2013 | 9:42 PM
I think you should be able to add the G80 differential but remember that the ratio has to match the front.
Old December 12th, 2013 | 12:36 AM
rcav2013's Avatar
Thanks...but i am bit confused...is the g80 the whole diff or is it the gear set and how would i find out the front axle ratio and if it matches...thank you....rob
Old December 12th, 2013 | 12:57 AM
G80 is the option code. Your axle ratio code is on the codes listing in your glove box or console compartment. Someone here can probably decode that for you or if not your dealer can through your VIN.
Old December 12th, 2013 | 1:29 AM
SWHouston's Avatar
Look in your Glove Box for a Sticker like Shark said, and give us all the codes which start with the letter "G".
Old December 12th, 2013 | 4:42 PM
rcav2013's Avatar
hi..the only g code I have according to the sticker in the glove box is GU4...but I also have YD3 which according to a decoder site I found YD3 Differential, driver-selectable locking rear
YD3 Differential, driver selectable rear locker
YD3 Front Axle For Scheduling GVW Plate
YD3 AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE
what do you think...thanks rob
Old December 12th, 2013 | 4:59 PM
flainn's Avatar
Uh ... sounds like yours was at least supposed to have a locker from the factory. Did somebody take it off?
Old December 12th, 2013 | 8:28 PM
rcav2013's Avatar
I hope not I bought the burb new...whatever came with the truck from the factory I hope is there
Old December 12th, 2013 | 8:34 PM
rcav2013's Avatar
btw my window sticker under the mechanical title does not say... differentilal, locking rear fully automatic.. like the window sticker for LT and LTZ models
Old December 12th, 2013 | 8:45 PM
whats the last eight of your vin?
yd3 isn't a build option for your vehicle. the decoder site is flawed
gu3 is the 3.08 rear end ratio.
