Replaced the front blower resistor twice,
figured i had a fan drawing too many amps, replaced that along with a new resistor...
1 week later, blew the resistor again.... Thats 3. Any suggestions? Hate to take it to the dealer and get hosed, but this is getting tiresome. |
Welcome to the forum. What year and model?
Not sure how you can draw enuf current to burn out the resistor w/o blowing the fuse. Are you sure they gave you the correct resistor? Does the fan come on before the resistor blows? |
2003 Suburban 1500 4wd front and back a/c control
Initially the OEM res blew (after 7 years!). Replaced it with aftermarket, worked fine for about 3 weeks then stopped (no speed worked). Replaced the res again and it worked for about 2 weeks then stopped (no speed worked). Decided my blower fan might be drawing too many amps so replaced that and new res. Worked fine for about a week, now all I have is high speed (5). There were 2 types of res blocks, mine is the 4 hole which they gave me. The other hole layout does not mate up.
I'm thinking I've got a bad connector or harness or switch. Not sure I can troubleshoot that or even replace it myself if bad. :mad: |
I think you should always have hi spd as that is direct 12V to fan. Might try getting on from the dealer parts dept and/or ask a tech if they have seen this type of behavior before.
