Replaced the front blower resistor twice,
Old May 10, 2010 | 8:03 PM
ashlinproperties@yahoo.com's Avatar
Default Replaced the front blower resistor twice,
figured i had a fan drawing too many amps, replaced that along with a new resistor...
1 week later, blew the resistor again....
Thats 3.
Any suggestions? Hate to take it to the dealer and get hosed, but this is getting tiresome.
Old May 10, 2010 | 8:24 PM
Welcome to the forum. What year and model?
Not sure how you can draw enuf current to burn out the resistor w/o blowing the fuse. Are you sure they gave you the correct resistor? Does the fan come on before the resistor blows?
Old May 11, 2010 | 2:35 PM
Default 2003 Suburban 1500 4wd front and back a/c control
Initially the OEM res blew (after 7 years!). Replaced it with aftermarket, worked fine for about 3 weeks then stopped (no speed worked). Replaced the res again and it worked for about 2 weeks then stopped (no speed worked). Decided my blower fan might be drawing too many amps so replaced that and new res. Worked fine for about a week, now all I have is high speed (5). There were 2 types of res blocks, mine is the 4 hole which they gave me. The other hole layout does not mate up.
I'm thinking I've got a bad connector or harness or switch. Not sure I can troubleshoot that or even replace it myself if bad.
Old May 11, 2010 | 8:50 PM
I think you should always have hi spd as that is direct 12V to fan. Might try getting on from the dealer parts dept and/or ask a tech if they have seen this type of behavior before.
Bjj1805
Jul 24, 2015 1:54 AM
marcuskight23
Jun 27, 2009 8:11 PM
tcrankwa
Jun 26, 2008 12:40 PM
aeroclimb
Dec 3, 2006 9:22 PM
Bobsyouruncle
Oct 31, 2006 12:11 AM
