Replacement engine
Hello,
need help with deciding to replace engine on my 2009 5.3 engine. have seen several different ways: 1. Replace engine 2. Install shield to prevent oil damage on engine. Or 3. Replace with used engine from different year 2012 or newer. please help! |
Welcome from Florida. What is option2? If you do this will you be able to keep your current engine? Why are you replacing the engine. My first case if I needed to replace an engine would be to rebuild the one I have.
Thanks,
no 2. oil in chambers of spark plugs 7 and 8. I was told this is internal engine failure. Looking online this has been problematic and GM has issued an fix for this problem. Well just answered that question. But if I rebuild or replace with similar engine with same problem should I put sheild on or will an engine from 2012 model or new with fixed problem be better? |
I don't know the answer to this, but changing years might mean that you have to change the computer as well. It's something you need to look into.
| All times are GMT -5. The time now is 1:02 AM. |
