Replacement engine
Old Dec 2, 2021 | 11:01 AM
Donnie1's Avatar
Default Replacement engine
Hello,
need help with deciding to replace engine on my 2009 5.3 engine.
have seen several different ways:
1. Replace engine
2. Install shield to prevent oil damage on engine. Or
3. Replace with used engine from different year 2012 or newer.
please help!
Old Dec 2, 2021 | 11:37 AM
Welcome from Florida. What is option2? If you do this will you be able to keep your current engine? Why are you replacing the engine. My first case if I needed to replace an engine would be to rebuild the one I have.
Old Dec 2, 2021 | 11:49 AM
Donnie1's Avatar
Thanks,
no 2. oil in chambers of spark plugs 7 and 8. I was told this is internal engine failure. Looking online this has been problematic and GM has issued an fix for this problem. Well just answered that question. But if I rebuild or replace with similar engine with same problem should I put sheild on or will an engine from 2012 model or new with fixed problem be better?
Old Dec 3, 2021 | 9:40 AM
I don't know the answer to this, but changing years might mean that you have to change the computer as well. It's something you need to look into.
itrustno1
Jan 16, 2014 5:36 PM
flh69
Oct 1, 2013 7:14 AM
lostsoul25
Jun 15, 2010 2:55 AM
92astro
Jan 4, 2009 10:05 PM
DAYMAN
Jul 9, 2007 7:12 AM
