Service Trailer brake system error AND reverse cam video loss
Hi all, I’ve search the forms and read a bunch of threads but I can’t find the information I’m looking for The other day I was installing some equipment towards the rear of the vehicle at 2014 Chevrolet suburban and when I was complete and started the vehicle I realized the check engine light is now on and I have discovered two problems the first is I am getting an alert on the dash telling me service trailer brake system and the other issue is when I put the car into reverse I am not getting any reverse back up camera picture on my factory radio display I’m gently looked around to see if I’ve accidentally disconnected any harnesses or damaged any wiring but I cannot find anything that makes me believe that has occurred so I’m thinking that it’s possible I bumped a harness wire loose on the inside the rear tailgate driver side pillar or possibly along the route that I ran wiring on the driver side floor board extending all the way up to where the emergency break footpedal is does anyone have any suggestions on what might’ve become loose disturbed or damaged? i don’t think I have accidentally disconnected any harnesses Also I’m thinking it might be helpful if someone has a schematic or can tell me the path of the harness or harnesses that are carrying the wiring for the two systems that are now having a problem I’d hate to take this to the dealer and get killed for something that I believe is most likely a very simple fix The last question that I have and I’m hoping it’s OK to post in the same thread is where is my best position to obtain a 15 amp switched ignition source? I tapped into a spot underneath the hood on the main distribution fuse panel that is labeled as miscellaneous ignition but I don’t believe that would be the cause of these two problems I’ve listed thanks very much this is my first post I find this board very informative |
Additional information
Additional information I neglected to mention that the first time I noticed it was not working and then put it in park and tried it again and I had a picture but the next time I put it in reverse it did not work so I do not think anything is blown I’m thinking it’s more likely a loose connection |
Welcome to the forum.
You might list just what you installed and what connections you made. |
Originally Posted by 73shark
(Post 359427)
You might list just what you installed and what connections you made. i obtained primary power via battery, switched ignition powers a relay that cuts off power of the line when vehicle is off |
