Slow to Warm Up
Cool weather is coming, and last year, it seemed to take forever for my Burb to warm up (inside).
My cooling system is ok, works well through the summer, so, I'm not saying that there's anything major wrong with it. However, I plan to do a clean/flush/hoses before next summer, and I was wondering if anyone knows or has used a specific manufacturers thermostat, which will get the temperature up to normal quicker. I KNOW I got a boxcar of room to do that to, but it seems like it should be better/faster than it is. |
You're in Houston, and you need heat?:D Seriously, I'd drop a 195 deg in it. My lumina has a fail safe t-stat. Last winter I couldn't get any heat hardly at all. I believe it has failed open, so besides a much needed flush it too will get a t stat.
HAY !, you don't understand !
It gets down to nearly a +40°F around here now and then, that's hard on my old bones ! :D :D PS: Are you saying that the stock Thermostat (which it probably has) is lower than 195°. I was under that impression that a 195° was pretty much an industry standard now, and assumed (from the dash readout which shows just under 200°) that was what is in there now. What I was looking for was "quicker" not "hotter". Once it finally warms, it's ok inside. |
Originally Posted by SWHouston
(Post 227314)
I'll definitely run some cold water over the old Stat, unless it's completely closed when I take it out.
I've not herd of a "Fail Safe Open" Stat, how does that work ? Also, there's the "Hinged Door" and "Raising Disk" type Stats, would you know if one of those types might get the temp up quicker than the other ? (I don't know how else to describe them :o) Not as a second thought, but, I also need to consider if I do replace the Stat with another type, that I get one that has as much flow fully open, as does the OEM. I DEFINITELY don't want to diminish the ability to cool, and in fact, that's more important down here, then a brief period of my personal comfort in cold weather. |
Interesting ! ;)
Does it say what temperature it thinks is an overheat ? |
(Post 227381)
Interesting ! ;)
Originally Posted by kevinkpk
(Post 227386)
once it has locked in the open position, it must be replaced. Thinking about it, my guess would be 220+? I might think about lowering the windows and turning on the Heater, or just pulling over, before that (if you knew where "that" was). I'd agree (guessing as you have) that it's probably well into the "+". I'd guess 212° + (15 lbs x 3.5°) -1°, would be reasonable, assuming 50%/50%. :rolleyes: |
I'd guess your 'stat is not closing fully. Stock is 195*. Read once a long time ago that the tolerance was +/- 20%. My last four Chevys ran at 200* steady.
