Striped caliper bolts.
I stripped the bolts on my 02 burban trying to replace the front pads. Has anyone experienced this problem? What did you do to fix it? Thanks
Ouch that hurt! I agree with george, But would like to expand on that thought a little further, First never modify a caliper or its mounting fixture by drilling holes in them, Second I have seen this alot and this is what i have found to be the only safe solution, Chase the threads on the caliper and make sure the damage is not so extensive that you cant get full thread depth! If depth cannot be attained the new bolts will continuely become loose and overtighting will stretch the threads even further adding to an already unsafe condition I.E. It will progressivly get worse ! if this is the case replace the caliper , These bolts are case hardened so not just any bolt will do, i would definently head to the junkyard or dealership and replace the bolts and if need be the calipers. dab a little antisieze on the bolt threads, it will aid in future removal and torque to spec. I know it sounds like overkill but i have seen it happen to many times keep in mind that 80 percent of your stopping power comes from your front brakes and it is a fact that those same brake setups are under sized for the application in these years of trucks! everybody give thanks to GM for that little oversite good luck with it
HAMMERGONE!!
HAMMERGONE!!
![Cool](https://chevroletforum.com/forum/images/smilies/cool.gif)
Im not sure, But why would you have to heat the mounting fixture or the caliper for that matter ? A point to make and a word of caution here, When applying heat to steel it changes its properties, In that it loses its overall tinsel strength and transfers the hardness to the surface of the metal! So if this is something you need or choose to do watch the heat and be aware what is taking place if overheated and definently do not cold quench with water let it air cool .
HAMMERGONE!!
HAMMERGONE!!
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
this is what the local shop did to my old car
Heli-Coil | HeliCoil Inserts | Helicoils Screw Thread Inserts | Helicoils | Emhart Teknologies
worked great!
worked great!
I think the OP stripped the Torx head. Not sure how unless using the wrong size Torx. Like using an SAE size in a metric head or vice versa. Damn Carter anyway.
