Suburban window help please!
My 2002 Suburban only has 6 volts going to the drivers window. Any ideas what is causing this? I already replaced the switch, checked all of the fuses and swapped the relays but it didn't help. The window works with direct power and the rear window works fine.
how much voltage at the fuse/relay?
Often window/lock problems are caused by broken wires in the door harness from bending back and forth.
