Tahoe 07 LT suspension bounce allot !
Old Jan 5, 2010 | 8:23 PM
  #11
15 Year Member
Does "coil spins" = "coil springs"? If so, not sure how psi. Maybe he was referring to lbs per inch of travel. Which springs do weaken w/ age. But the spring rate doen't change that much, they just start to sag. Unless you have a lot of miles on it, I wouldn't think your springs would be that weak.
Old Jan 6, 2010 | 8:15 AM
  #12
grandcas's Avatar
Cool
thank you, there is not much mileage and I bought by a GMC dealer, so I trust the odometer is not modified, probably the previous owner used a one of those trailer attachment without wheels (for luggage or something like that..... and the rear suspension received allot of weight ...... I guess.....<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
This is what I’m gone to do<o></o>
First I'll make the change of the coil springs/spins, test the bouncing...<o></o>
Then I will add the bags I mention before, this because I will trailer a heavy boat, close to the maximum capacity of the truck.<o></o>
<o></o>
I'll keep the forum updated on my findings.<o></o>
<o></o>
just a final note, the bouncing problem is till the point to my lower back (lumbar bones) hurts me when the trucks moves/bounce to the sides (when crossing non a perpendicular bumper or train rails in the road), hope I explained myself well here.... so yes is a problem...<o></o>
<o></o>
Old Jan 31, 2010 | 6:48 PM
  #13
grandcas's Avatar
problem solved.
new coil springs and bags in side of them
so stiff as possible.
thanks fo the help.
HoosierShadow
Oct 8, 2015 7:55 PM
stevenson98
Oct 21, 2014 3:13 PM
cwincek
Sep 16, 2012 11:04 PM
turbotee
Aug 5, 2012 8:36 AM
JHancock
Sep 11, 2011 9:55 PM
