tahoe cranks but wont start
Old Mar 26, 2013 | 8:55 PM
Logan Rick's Avatar
Default tahoe cranks but wont start
1997 chevy tahe vortec motor cranking over but wont start i got home from work last night car was driving fine went to start today and nothing i am not hearing the fuel pump prime but its kinda hard to do this by your self but will have some help tmrw but cld the pump just go out like that? i put 2 gallons of gas in just to make sure it had fuel cause i was kinda low but kinda stumped on why it would do this HELPP
Old Mar 27, 2013 | 1:00 PM
mulmur1's Avatar
You should check to make sure that you have not blown a fuse on the fuel pump. Then check that there is power going to the pump. Also, check the fuel pressure, if the pump is getting power.
If it isn't the fuel pump, you will have to start going through a no start diagnosis.
Good luck with your repair. It will be easier to figure out with some help.
Old Mar 28, 2013 | 9:29 PM
cleveland63b's Avatar
yea the pump can randomly fail...happens a lot just check fuel pressure and for power to the pump as stated
gjo5475
Feb 20, 2015 8:50 AM
Slugga
Sep 24, 2010 9:41 PM
kenehsr
Sep 5, 2010 5:08 PM
74chevy4life
Feb 14, 2008 10:13 AM
mike78olds
Sep 17, 2007 9:33 AM
