Test driving a 2005 suburban... heard 3 chimes
I'm test driving a 2005 Suburban z71 this weekend.. Driving to HomeDepot this morning I heard 3 chimes.. I looked at the dash and nothing was lit up like a warning.. I did notice the that gas gauge was 3/4 full. Does it chime when it drops in gas? Also since this is my first suburban that i'm looking at, is there anything specific I should look for? It has 115,000 on it. I'm dropping it off at my mechanic tomorrow to have him go over it.
I would do a key on to ignition on no crank position and check to see that all of the lights come on , on the IP, may have to do it a couple of times to see / check them....
consider checking that all doors are closed, that the seat belts are in use for the occupied seats... make sure all fluids are topped off under the hood... |
Fuel pump - listen for any whining back near the fuel tank. It's an expensive fix, and they usually die around 100-125K.
Front hub/bearing assemblies are expensive to replace - check them. Power window regulators are a known issue - make sure all windows raise and lower smoothly and quickly. Check the shock absorbers - if it has the ZW7 suspension, the rear shocks are very expensive to replace Brakes are also an issue - check the calipers and rotors. Check the A/C condenser and the clutch Check the body for rust on the bottom of the rear panels, just in front of the rear wheels; and check the bottoms of the doors for rust. Those are all the major things I can think of - don't let my list scare you. They're great trucks. My 01 has 188,000 miles, and I would not hesitate to hook up my 7,000 lb trailer to it tomorrow and drive across the country. Original engine and transmission. |
Well my mechanic went over it and gave it a thumbs up.. Just a few little maintenance this that need to be done.. One thing he noticed was the driver sideview mirrow was loose. I looked at it, it's not the actual mirror but the whole part that folds in. I tried the power folding option, the passenger side folds in but you can hear the motor on the driver side but it doesn't fold in. Is there a fix for that or will I just need to buy a new one?
Oh.. and the beeping was for the gas cap.. Never had a car that told you that was loose. |
